Arma 3: How do we disable battle-eye?
Hi everyone,
Just wondering if anyone has had any luck disabling battle-eye in the Arma 3 template? I would usually do it in the server config but it exists in the section of AMPserver.cfg that needs to be immutable and there isn’t a GUI asset for that variable as far as I can see.
Many Thanks
You don’t, AMP requires it in order to function. Battleye is tied into other systems that AMP relies on.
Hi Mike,
Thanks for the reply, I’ll try to sort the battle-eye issues on the client sides then.
Take care
