OS Name/Version: AlmaLinux 8.6
AMP ver: v2.4.3 14/03/2023 23:15
Product Name/Version: Ark SE v357.3
Linux machine has 48Gb RAM and 10Tb RAID 1 drives.
This was all after a fresh minimal install of AlmaLinux and all updates performed. AMP was also a fresh install.
After starting Ark, the console is stuck in “Starting ARK: Survival Evolved…” and stays in this state even when the game is up and running.
Stopping the instance from the “Instance list” screen stops the instance, but I have noticed changes in the game from the last 30 odd minutes seems to get lost. Im guessing its due to the instance thinking its still starting up.
Another thing I have noticed is that the instance’s console never gets any updates and also only has the Abort button on top (it too thinks the instance is starting).
- Create ARK instance
- Start ARK
- Notification on screen is “Starting ARK: Survival Evolved…” which remains until you abort the instance (you cant stop it inside the instance menu as it thinks its still starting). It takes about 4 minutes for the game to start being served, but thats normal. Whats not normal is for AMP to think its still starting.
Restarted the instance multiple times. The instance is part of a cluster of ARK instances. I have also tried stopping the other instances but this has not helped.
I have tried rebooting the linux machine with no change.
