OS Name/Version: Windows Server 2019
Product Name/Version: AMP 2.3.4.3
Problem Description: After updating to version 348.2 today, multiple servers have been stalling in an “Application State: Starting” state, while the server is live and fully playable. Out of 13 servers, 11 currently within AMP show that they are still “starting” while being connectable. After confirming that the game is showing as live and playable - the AMPLog on a broken server states:
Success! App '376030' fully installed.
[15:08:00] [System:let Activity] : Starting the application.
[15:30:31] [System:let Warning] : RCON connection failed, console write unavailable.
[16:08:05] [System:let Activity] : Starting the application.
[16:35:36] [System:let Warning] : RCON connection failed, console write unavailable.
[16:38:28] [System:let Activity] : Downloaded file 376030/ShooterGame/Saved/Config/WindowsServer/GameUserSettings.ini (API mode)
[16:39:15] [System:let Activity] : Uploaded file 376030/ShooterGame/Saved/Config/WindowsServer/GameUserSettings.ini (API mode)
[16:39:21] [System:let Activity] : Starting the application.
[16:45:30] [API:let Activity] : Protected setting ARKModule.ServerSettings.ServerAdminPassword changed.
[16:45:32] [API:let Activity] : Protected setting ARKModule.ServerSettings.ServerAdminPassword changed.
[16:45:50] [System:let Activity] : Starting the application.
[16:47:53] [System:let Activity] : Downloaded file 376030/ShooterGame/Saved/Config/WindowsServer/GameUserSettings.ini (API mode)
Unfortunately the game server logs do not show as being saved regardless of restart/start/shutdown.
Stop instance running 247.1
Use AMP built-in “update” option within instance to run update.
Verify update to Server Version 348.2
After successful update, attempt to start game server.
Verified Server update both with AMP and ASM (ARK Server Manager)
Confirmed that servers are live by both RCon verification and in-game joining
Reviewed any .ini changes that would prevent the game to post
Restart entire server
