The deployment Template feature, as mentioned in this post Configuring AMP for Enterprise or Advanced Usage , which should come with the purchase of a Advanced Licence Key, as I did, is not showing up
I did not yet reactivate my ADS, as I was not sure, if It would fix it and I wanted to ask beforehand, I also dont know, how to “stop” and in the after “start” my ADS, instead of restarting, could you provide me a quick guide, on how to “stop” and “start” my ADS?
Templates are handled by the ADS instance (the AMP instance that runs the main web panel page), so reactivating it tends to be the way to get things rolling if the feature wasn’t activated automatically.
Thank you very much, could have also found that information by just searching a bit, next time ill first search, before asking trivial questions, the template feature is also working now, thank you and excuse me for asking something this dumb.
