Application Deployment - OIDC config not syncing to instances
Virtualization ProxmoxLXC
I’m trying to add OIDC to ADS and my managed instances
My ADS instance is behind a Caddy reverse proxy. No matter if I recreate the instance itself, I am unable to get OIDC-based login to the instance itself to work. I have tried various variations of “Default Auth Server” including my Caddy hostname, the default localhost and unset and still have the same issues each time.
  • Add OIDC details to the ADS instance’s UI
  • Attempt to log into the instance through ADS
  • Get error “Failed to login to remote instance - Account Unavailable”
  • If I manually activate the user in the instance (after logging in with user/pass credentials), I get “Failed to login to remote instance - Token Rejected”
