Application Deployment - Need to keep reentering the license key into AMP
License key stops working after a few days
The server has started going offline every few days and when I check the license key is missing from the instance deployment section. I havent made any changes to the server since starting it almost a year ago but this started happening about a month ago so im not sure what could be causing this.
  • Create server for local play
  • Only task AMP runs is server, restart and backup.
  • Starts needing the license key multiple times a week
That’s often caused by hardware changes on the machine. Do you have a VPN installed or any settings that change the MAC address on reboot? (some VMs have that enabled by default)
