Application Deployment - Logging in issue FTP file access
Product AMP ‘Callisto’ v2.5.1.6 (Mainline)
Virtualization QEMU_KVM
I would like help in accessing some few things on my server
I wanted to make sure that I have installed all of the plugins into my server to pay more money in making sure the server gets what it needs to survive at its level of expertise. Thank you whoever helps me throughout the admins of Hostinger.
  • I downloaded FTP File access, but I couldn’t completely login at all in the end
  • I tried to put the same password as I logged in with but to no avail it didn’t seem to work at all
  • I gave up and asked you guys what to do next in the following procedure
Can you explain in more detail exactly what you’ve done? Your steps so far are very vague.
I went ahead and added the login details of all whats needed from Hostinger to login into the Admin Panel all I need is the password to the panel and somehow the password is not working or has not been set. Please let me know what to do if the password has not been set?
You need to talk to Hostinger in this case then and have them sort out your login details.
