Field | Value |
Operating System | Linux - AlmaLinux 9.4 on x86_64 |
Product | AMP ‘Phobos’ v2.6.0.0 (Mainline) |
Virtualization | QEMU_KVM |
Application | Application Deployment |
Module | ADSModule |
Running in Container | No |
Current State | Indeterminate |
Activate License after AMP and VPS upgrade
Machine ID Hash attached to my Liscnse isn’t going to match anymore due to the VPS being upgraded need help with this issue. As it’s the same machine and IP just upgraded CPU and RAM and Diskspace for more power. I only have 2 activation out of 50 so that isn’t the issue as this is just for me and my friends to play on. Any help with this would be apprciated.
- Tried all suggestions in Discord and Your Forums. ampinstmgr deactivate, ampinstmgr reactivate ect even on clean reinstall.
- ampinstmgr reactivate several times same outcome.
- Clean wiped install still same problem.
[01:55:18] [Program Info/1] : Starting AMP version 2.6.0.0 (Phobos), built 23/10/2024 20:49
[01:55:18] [Program Info/1] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[01:55:18] [Core Info/1] : Loading configuration from provisionargs.kvp…
[01:55:18] [Program Info/1] : Running in a QEMU KVM environment.
[01:55:18] [Program Warning/1] : Current time zone is set to Mountain Standard Time - It is recommended you switch to UTC+0 to avoid time-zone related issues
[01:55:18] [Program Info/1] : OS: Linux / x86_64
[01:55:18] [Program Info/1] : CPU: Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz (16C/16T)
[01:55:18] [Program Info/1] : RAM: 31838MB
[01:55:18] [Program Info/1] : AMP Instance ID: ||somenumber||
[01:55:18] [Core Info/1] : Loaded GenericModule version 2.6 by CubeCoders Limited
[01:55:18] [Core Info/1] : Metrics publishing is enabled at udp://localhost:12820.
[01:55:18] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
[01:55:18] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
[01:55:18] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
[01:55:19] [Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[01:55:19] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
[01:55:19] [Loader Info/1] : Loaded AnalyticsPlugin by CubeCoders Limited
[01:55:19] [System Error/10] : Missing plugin/assembly: MaxMind.Db (/home/amp/.ampdata/instances/MikesGamingWorld01/Plugins/MaxMind.Db/MaxMind.Db.dll) for
[01:55:19] [Loader Info/1] : GenericModule requests dependency steamcmdplugin…
[01:55:19] [Loader Info/1] : Loaded steamcmdplugin by CubeCoders Limited
[01:55:19] [Loader Info/1] : GenericModule requests dependency RCONPlugin…
[01:55:19] [Loader Info/1] : Loaded RCONPlugin by CubeCoders Limited
[01:55:19] [Core Warning/1] : No such setting node: GenericModule.Meta.Prerequsites - maybe the relevant plugin/module isn’t loaded?
[01:55:19] [Core Info/1] : Performing activation, please wait…
[01:55:20] [System Error/9] : Activation failed: VerificationFailed
[01:55:20] [System Error/9] : Licence state: NoMatchingMachineId
[01:55:20] [Core Info/1] : Failed to activate: Verification Failed
[01:55:20] [Program Info/1] : -configonly specified or activation performed. Saving settings and shutting down. This is perfectly normal.
[Info/11] Done.
