Application Deployment - Is it possible to enable SSL for port 8888?
Product AMP ‘Callisto’ v2.5.0.12 (Mainline)
Virtualization QEMU_KVM
Is it possible to enable SSL for port 8888? It is active for 8080
Is it possible to enable SSL for port 8888? It is active for 8080, running a minecraft instance with a plugin which is configured to use 8888, it is accessible via http, but I would like it to be secure and use SSL, the domain is mc.autotail.pro:8888, is it possible to make it secure?
  • Check mc.autotail.pro:8888, it uses http instead of https
  • mc.autotail.pro is working with SSL
  • The Dynmap plugin that is configured on the server uses the port 8888
You would need to refer to the plugin’s documentation, or use a reverse proxy to proxy it to a different subdomain with a cert, not really something AMP is capable of helping you with.
