Application Deployment - I'm think there's a penetration attack going on
Operating System Linux - Ubuntu 20.04.6 on x86_64
Virtualization QEMU_KVM
I’m think there’s a penetration attack going on
So everything started some weeks ago, I’ve seen some logins with strange usernames like “admin” and “root”, “system”, etc…
They were just 5-7 times in a day
Now there are hundreds on them each 5 minutes.
The fact is that the login attempts are being made by 127.0.0.1, which is local, what can I do?
In the following picture, there’s a part of the Logs that shows the unauthorized and unrecognized accesses.
  • Access the panel
  • See the sidebar
  • Clicking on the audit log
Yup, this is normal for a service exposed to the Internet. But we can see that AMP is banning IPs by itself. Nothing really to worry about.
If they’re coming from localhost then you’ve got something misconfigured. Are you using a reverse proxy?
Piggybacking off what Mike said, if you have a reverse proxy, be sure you follow this guide. Also, if you aren’t using X-Forwarded-For headers, use them.
