| Operating System | Linux - Ubuntu 20.04.6 on x86_64 |
| Product | AMP ‘Decadeus’ v2.4.6.6 (Mainline) |
| Virtualization | QEMU_KVM |
| Module | ADSModule |
| Running in Container | No |
Managing a Instance
Every Instance (Local and 2 Targets) i get this Error: Failed to login to remote instance. null
I have not changed ANYTHING in AMP, nor restarted AMP, two hours before this problem occurred. While in use, I was suddenly kicked out of my game server instance onto the controller instance and received this error message. From there, nothing worked anymore. I couldn’t open or edit any instances. Once, I was able to fix this with ‘ampinstmgr resetlogin’ for each individual instance. However, after an hour, it started again, and this time, unfortunately, that doesn’t work. To reiterate: on both Instances, I had NOT changed anything in AMP up to 30 minutes before. I was only working on my game server and its files.
I have already shown IceOfWraights some AMP logs. He told me that I should then create an issue post.
- There is no way because it appears randomly
