Application Deployment - Cant Manage Instances
Operating System Linux - Ubuntu 24.04.4 on x86_64
Product AMP ‘Deimos’ v2.7.2.0 (Mainline)
Virtualization QEMU_KVM
Trying to look at my setings of my micraft instence but get a mis match get it on a broser i normaly do not use.
The AMP frontend that has been loaded (v2.7.2.0) does not match the backend (v2.7.2.8). Please clear your browser cache (or force reload with CTRL+F5) as well as any upstream proxy caches.
  • Instances
  • Manage inctance button
  • see the tab open and see the error
I’m having the same issue.
Try another device in the house to connect to the Server application, I have found using my Ipad works fine connecting to the instances to start and stop and fix
