Context
- OS Name/Version: Debian GNU/Linux 11 (bullseye)
- Product Name/Version: AMP Instance Manager v2.4.6.4 built 06/09/2023 12:13
Background:
Using some hosting service I have VM instance with pre-installed AMP panel.
After ordering VM, I was given URL of AMP’s admin panel (bare IP-addr and port which AMP is listening to) without SSL.
My mistake was that I had launched a custom game instance without making post-configuration steps first. So I went to admin-interface and proceeded with setting certain game instance up.
What I try to achieve and what I did:
Now I decided to configure Nginx as reverse proxy. I’d like Nginx to proxy all requests to ADS01 instance and make ADS01 instance be bound to 127.0.0.1:8080.
I managed to configure Nginx by running ampinstmgr setupnginx.
So now Nginx is running and proxies requests like that:
/etc/nginx/conf.d/mcserveramp.site.conf
server {
server_name ***;
location / {
proxy_pass http://127.0.0.1:8080;
And it seems OK for me.
And meanwhile I have two AMP instances:
amp@srv1234:~$ ampinstmgr -l
[Info] AMP Instance Manager v2.4.6.4 built 06/09/2023 12:13
Instance ID │ ***
Module │ ADS
Instance Name │ ADS01
Friendly Name │ ADS01
URL │ http://123.123.123.123:8080/
Running │ Yes
Runs in Container │ No
Runs as Shared │ No
Start on Boot │ Yes
AMP Version │ 2.4.6.6
Release Stream │ Mainline
Data Path │ /home/amp/.ampdata/instances/ADS01
Instance ID │ ***
Module │ Minecraft
Instance Name │ minecraft-server01
Friendly Name │ minecraft-server
URL │ http://123.123.123.123:8081/
Running │ Yes
Runs as Shared │ No
Start on Boot │ Yes
Data Path │ /home/amp/.ampdata/instances/minecraft-server01
*where 123.123.123.123 is public IP-addr
And I tried to run ampinstmgr --RebindInstance ADS01 127.0.0.1 8080.
However I got the next log:
amp@srv433869:~$ ampinstmgr --RebindInstance <ads01_uuid> 127.0.0.1 8080
[Warning] WARNING: Rebinding ADS will break logins/management for all instances/controllers that rely on it.
[Error] -- You will not be able to manage any existing instances if you do this --
[Warning] If you are not familiar with how AMP manages authentication and logins, ask for support before doing this.
[Info] This prompt is case-sensitive. You should avoid rebinding ADS if at all possible.
Are you sure you want to rebind ADS? You will need to manually reconfigure any managed instances. [Y/N]
Question
As far as I understand from the log above, I’m going to lose everything related to the instance named ‘minecraft-server01’ if I try to rebind ADS01. How can I avoid losing data? What should I do?
Steps to reproduce
- Setup AMP Game Panel
- Setup any game instance
- Try to rebind AMP’s ADS instance using (like ampinstmgr --RebindInstance <ads_uuid> 127.0.0.1 <any_port>`), and you’re going to get that warning log I’ve shown above.
