No valid AMP licence was found. Please run ampinstmgr reactivate DragonDimensions
But when i run ampinstmgr reactivate DragonDimensions, i get
[Error] FileNotFoundException
[Error] [0] (FileNotFoundException) : Could not load file or assembly ‘mHttp, Version=0.1.6296.32466, Culture=neutral, PublicKeyToken=null’ or one of its dependencies. The system cannot find the file specified.
[Error] ReflectionTypeLoadException
run ampinstmgr reactivate Dragondimensions
reboot, reinstall AMP Manager, delete cache and reinstall AMP Manager,
I’ve let the reactivate directive run for almost half hour and it never completes. I end up killing the process. Is there an equivalent to amp +core.amp.license KEYHERE -configonly anymore? I run that and get that its not a valid module
the entire error is,
[Error] [0] (ReflectionTypeLoadException) : Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.
[Error] at InstanceManagerPlugin.LocalInstanceManager.GetProvisionArguments(String ModuleName)
I am getting this same error on my Windows 10 target. Using latest version on mainline. Logs show nothing, no errors at all. Instances appear to be running in the web UI but the output of the status command shows that they are not running. Trying to manage an instance simply says ‘Check that it is running, and if it fails to restart’ etc.
Not sure what else to try.
