Amp won't start. (127.0.0.1)
OS Name/Version: Windows 10
Product Name/Version: AMPSetup.msi
Problem Description: Every time I try to start the “AMP Instance Manager” and it can’t connect to the local host address/ it isn’t available. It worked before the update.
  • Install
  • AMP Instance Manager
Ran mpinstmgr restart ADS01
Change the service startup type to “Delayed Start”
That did not work. Any other ideas?
Reboot having changed that :slight_smile:
Did not work either. Anything else?
If you restart ADS01 on the command line, does it spring to life?
That did not work. But when I restart it, it says “[Warning] Failed to register job process”. Does that have anything to do with it?
