OS Name/Version: Debian 10
Product Name/Version: AMP ‘Triton’ 2.3.2.10
Since update AMP ‘Triton’ 2.3.2.10, Forge server can’t start, and/or be installed:
- It tries to run the forge installer with graphics and give this error (ofc it will not work it’s a server with console only, was working fine before update), and the currently installed server will not work anymore (was working fine before this update):
22:58:28
JVM info: Oracle Corporation - 17.0.2 - 17.0.2+8-LTS-86
java.net.preferIPv4Stack=true
Found java version 17.0.2
22:58:29
Exception in thread "main"
java.awt.HeadlessException:
No X11 DISPLAY variable was set,
but this program performed an operation which requires it.
at java.desktop/java.awt.GraphicsEnvironment.checkHeadless(GraphicsEnvironment.java:166)
at java.desktop/java.awt.Window.<init>(Window.java:553)
at java.desktop/java.awt.Frame.<init>(Frame.java:428)
at java.desktop/java.awt.Frame.<init>(Frame.java:393)
at java.desktop/javax.swing.SwingUtilities$SharedOwnerFrame.<init>(SwingUtilities.java:1919)
at java.desktop/javax.swing.SwingUtilities.getSharedOwnerFrame(SwingUtilities.java:1995)
at java.desktop/javax.swing.JOptionPane.getRootFrame(JOptionPane.java:1695)
at java.desktop/javax.swing.JOptionPane.showOptionDialog(JOptionPane.java:874)
at java.desktop/javax.swing.JOptionPane.showMessageDialog(JOptionPane.java:676)
at java.desktop/javax.swing.JOptionPane.showMessageDialog(JOptionPane.java:647)
at net.minecraftforge.installer.SimpleInstaller.launchGui(SimpleInstaller.java:177)
at net.minecraftforge.installer.SimpleInstaller.main(SimpleInstaller.java:147)
- Under Configuration - Server Settings, if you chose “Forge” in “Server Type”:
a) Forge Version option is not showing any version in the list, so you can’t select any
b) Trying to install/update give the following error:
Download / Update failed : Couldn't determine the URL to fetch an update from. You may need to install this server type manually.
All other “Server Type” are working except Forge since this update.
- Run an already configured Forge install
- Create a new Minecraft Java instance
- Try to install Forge
Rebooting server
Try installing new instance with forge
