Amp Sftp not accessible after install
OS Name/Version: debian 12 lxc in proxmox AMP Release “Phobos”
v2.6.0.6, built 20/11/2024 20:57
Problem Description: Sftp not accessible(Internally same lan), seems to connect but does not allow entering the user /pass combo from the setup / web panel
provides syntax highlighting.
-lxc debian 12 container in proxmox
-reconfigure locales for utf8 support
-install using the script
options:
docker yes https no
looked for simmilar issues but found none
Are you connecting to SFTP on AMP’s port(s)? (2223-222x)
And sanity check, if you’re using 2FA you need to append the code to your user’s password when connecting.
no 2fa and I tried both 22 and 2223
Port 22 is for the system, won’t work with your AMP login.
Double check that the port is accessible in the AMP machine’s firewall.
(ampinstmgr dumpfirewall as root)
dumpfirewall marks port 2223 and 2224 as availible for sftp from the plugin
file zilla also seems to grab the answer from the server “SSH-2.0-AMP Embedded SSH// AMP”
I think its a permission thing maybe
If your user is a Super Admin, it probably wouldn’t be a permissions issue.
Try using WinSCP instead of FileZilla and see if that works
there is no winscp for linux afaik, sftp is standardized tho
You’re running Linux as your desktop OS?
Mine just has SFTP built into the file manager, you could give that a go and see it that has better luck than FileZilla.
