OS Name/Version: Windows Server 2022
Product Name/Version:AMP Release “Callisto”
v2.5.0.4
Instance crashes on start with this
Failed to start AMP. Exit code was -2146232797
Amp says running 16/15 instances really running 8
[Error] OS: Windows (x86_64/None)
[Error] Module: MinecraftModule, Version: AMP 2.5.0.4
[Error] Instance ID: 6305cad5-bf5d-4f22-8210-cbfecb077f9e
[Error] SocketException
[Error] [0] (SocketException) : Only one usage of each socket address (protocol/network address/port) is normally permitted
[Error] at Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress)
at Net.Sockets.Socket.Bind(EndPoint localEP)
at Net.Sockets.TcpListener.Start(Int32 backlog)
at m.Http.HttpBackend.ConnectionLoop()
[Error] --- End Exception Data ---```
```[08:00:00] [ErrorReporter Error] : [Error] --- Begin Exception Data ---
[Error] IOException
[Error] [0] (IOException) : All pipe instances are busy.
[Error] at IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at IO.Pipes.NamedPipeServerStream.Create(String fullPipeName, PipeDirection direction, Int32 maxNumberOfServerInstances, PipeTransmissionMode transmissionMode, PipeOptions options, Int32 inBufferSize, Int32 outBufferSize, PipeAccessRights rights, SECURITY_ATTRIBUTES secAttrs)
at IO.Pipes.NamedPipeServerStream..ctor(String pipeName, PipeDirection direction, Int32 maxNumberOfServerInstances, PipeTransmissionMode transmissionMode, PipeOptions options, Int32 inBufferSize, Int32 outBufferSize, PipeSecurity pipeSecurity, HandleInheritability inheritability, PipeAccessRights additionalAccessRights)
at IO.Pipes.NamedPipeServerStream..ctor(String pipeName)
at GSMyAdmin.Core.<SetupNamedPipe>()
All ports are not in use and they are all different. but its saying double of every port we are using
8080, 8080, 8081, 8081, 8082, 8082, 8083, 8084, 8085, 8086, 8080, 8081, 8082, 8083, 8084
