Hello AMP Community,
I have an AMP server with a Satisfactory AMP instance and I am trying to find out where is the location on the linux server running AMP of the save game files.
If you can provide any pointer that would be great.
Cheers!
Cheers!
You can’t access it from within AMPs file manager, as the game doesn’t allow AMP to change where the data is stored.
I am really missing something …
Is AMP set up to use Docker mode?
Hello Mike. Yes, it is configured to use docker mode. Thanks.
In that case you need to go into the instances datastore directory, and you’ll find a hidden directory called .virtualhome which will contain the games data.
Thanks for the tip.
For future reference with AMP configured with docker and AMP installed in /home/amp the savegames can be found at:
root@amp:/home/amp/.ampdata/instances//.virtualhome/.config/Epic/FactoryGame/Saved/SaveGames/server#
Not to drag this back up, but I’m having the exact same problem for Windows. I’ve exhausted everything regarding Satisfactory save locations in the dedicated server documentation and AMP documentation. I only found a symlink, but I don’t want to break the permissions on it without knowing how to back it up.
Just zip and download the Saves dir?
The symlink is meant to make the saves accessible in the datastore, given Satisfactory creates them in the Network Service AppData directory
Here is the location on Windows for those searching:
C:\Windows\ServiceProfiles\NetworkService\AppData\Local\FactoryGame
