OS Name/Version: Ubuntu Server 22.04
Product Name/Version: AMP Instance Manager v2.4.1.2 built 21/12/2022 17:55
Nothing, its a freshly installed server, primarily to run Minecraft with AMP. I dont know what causes it to shutdown.
Minecraft was creating a high pressure on the server, so it could explain the shutdown. But it doesnt explain (at least for me), the reason why the restart doesnt work.
I try to replicate the problem to check the dmesg output.
But yes it looks like it was killed because of memory space (i disabled the swap file).
In either case, it will work for me, as its currently just to test if everything works, before i buy new components.
Im just still questioning, why i get the error when i try to restart the instance?
