AMP RAM java settings?
But I already posted the content of the latest AMP_log above.
AMPLOG 2022-03-24 07-10-35.log
[07:10:42] [Core Info]            : AMP is up-to-date.
[07:12:55] [APIService:Anonymous Warning] : Access denied: You do not have permission to use this method (GSMyAdmin.WebServer.GetActiveAMPSessions) at this time. This method requires the Session.LoggedIn permission. (Origin: 192.168.0.6:62691)
[07:13:01] [Core:admin Info]      : 0675d2bc6f24ecdcd01170e8e1660f23bded8afc2528c58751a9310dccdf75f0
[07:14:00] [APIService:Anonymous Warning] : Access denied: You do not have permission to use this method (ADSModule.GetInstances) at this time. This method requires the Session.LoggedIn permission. (Origin: 192.168.0.6:62733)
[07:14:03] [ADS:admin Activity]   : Managed remote instance SPEEDZONE_1 at http://127.0.0.1:8081/
[07:14:03] [Auth:admin Activity]  : Authentication token for admin requested by ManageInstance on behalf of admin
[07:14:07] [APIService:Anonymous Warning] : Access denied: You do not have permission to use this method (GSMyAdmin.WebServer.GetActiveAMPSessions) at this time. This method requires the Session.LoggedIn permission. (Origin: 192.168.0.6:62749)
[07:15:00] [APIService:Anonymous Warning] : Access denied: You do not have permission to use this method (ADSModule.GetInstances) at this time. This method requires the Session.LoggedIn permission. (Origin: 192.168.0.6:62760)
[07:17:52] [ADS:admin Activity]   : Managed remote instance SPEEDZONE_1 at http://127.0.0.1:8081/
[07:17:53] [Auth:admin Activity]  : Authentication token for admin requested by ManageInstance on behalf of admin
[07:17:55] [APIService:Anonymous Warning] : Access denied: You do not have permission to use this method (GSMyAdmin.WebServer.GetActiveAMPSessions) at this time. This method requires the Session.LoggedIn permission. (Origin: 192.168.0.6:62942)
[12:34:49] [ADS:admin Activity]   : Managed remote instance SPEEDZONE_1 at http://127.0.0.1:8081/
[12:34:49] [Auth:admin Activity]  : Authentication token for admin requested by ManageInstance on behalf of admin
[12:34:53] [APIService:Anonymous Warning] : Access denied: You do not have permission to use this method (GSMyAdmin.WebServer.GetActiveAMPSessions) at this time. This method requires the Session.LoggedIn permission. (Origin: 192.168.0.6:64714)
[13:05:42] [InstanceManager:admin Info] : Stopping instance SPEEDZONE_1...
[13:05:47] [InstanceManager:admin Info] : Instance SPEEDZONE_1 has stopped.
[13:05:48] [APIService:Anonymous Warning] : Access denied: You do not have permission to use this method (ADSModule.GetInstances) at this time. This method requires the Session.LoggedIn permission. (Origin: 192.168.0.6:49227)
[13:05:54] [Core:admin Info]      : 3bd5212baf029a32786d68d17ce56026ae7626f9296c2bc342f9e1240882d14a
[13:06:00] [APIService:Anonymous Warning] : Access denied: You do not have permission to use this method (ADSModule.GetInstances) at this time. This method requires the Session.LoggedIn permission. (Origin: 192.168.0.6:49229)
[13:06:35] [Core:admin Info]      : Stop requested: AMP restart requested via API
[13:06:35] [Core Notice]          : AMP shutdown requested.
[13:06:35] [Core Notice]          : Stopping Application...
[13:06:40] [Core Notice]          : Stopping Web Server...
[13:06:40] [WebServer Info]       : Web server shutdown.
[13:06:40] [Logger Warning]       : RouterTimer@10Hz stopped
[13:06:40] [Core Notice]          : Goodbye!
Rest in peace - Stephen Hawking 1942-2018
That’s an old log. You need a fresh one that shows the log output from you reconfiguring the instance.
You might also want to turn on debug mode: Diagnosing AMP issues · CubeCoders/AMP Wiki · GitHub
This is a new file log, and I have changed the Monitoring.LogLevel to 0:
Can you see anything that would explain this problem?
(Had to wait 5 hours to be able to post again :wink: )
just been reading this seems you are not logged in and or do not have permission to do the action cherck your permissions with admin account or create a new user
This method requires the Session.LoggedIn permission you are logged out by the looks of it
