Amp Panel wont load
OS Name/Version: Win 11 /23H2
Product Name/Version: (Always use the full version number - not ‘Latest’) Amp Pro. dont know what version as wont load
Problem Description: Hmmm… can’t reach this page
127.0.0.1 refused to connect.
Try:
ERR_CONNECTION_REFUSED
provides syntax highlighting.
  • Step 1 double click on Amp Instance Manager Icon
  • Step 2
  • Step 3
Actions taken to resolve so far: stopped all instances running and ran repair of amp in new download.
Cleared browser cach.
Added firewall rule for port.
checked all AMP ports are OK
netsh http add iplisten 127.0.0.1
I had this issue just now as well.
Running “ampinstmgr restart ADS01” in a command prompt solved it for me, worth a try :+1:
Perfect!!! worked for me too! Thank you!!
