Hello,
I am trying to setup a subdomain to access my amp panel remotely without using the port at the end. In order to do this I need to know where the directory for the web interface is at so that I can forward the port to that directory in my .htaccess or vhosts files. I’ve looked around and I am not seeing it anywhere.
Apache isn’t supported with AMP. You must use nginx which AMP can auto configure to be a reverse proxy.
Does something in AMP configurations needs changed once I install nginx or will it automatically use it?
Run ampinstmgr <(wget -qO- getamp.sh) postSetupHTTPS as root.
