AMP not responding properly to systemd shutdown calls
OS Name/Version: Linux
Product Name/Version: AMP 2.6.2.6 - 20250804.1
AMP is causing Minecraft worldfiles to corrupt by not shutting down properly.
May also be related to timing out, and systemd killing it for that reason.
  • Start AMP on Linux after normal server rundown
  • Shutdown server with instances running
  • AMP collapses because systemd must kill it by force when it does not shut down normally
Nothing possible; this is AMP related
Are you using docker based instances or normal ones? It’s a known issue with Docker based instances which has been resolved for the next update.
