AMP login reset
Hello, I’m contacting you because I’m unable to connect to AMP. I purchased a lifetime license key.
I installed AMP Docker with my license key on Unraid.
I tried the first command:
“Please enter a value for the instance name,” and then I entered ADS01. The following message appeared:
[Error/1] No such instance matches the name: “ADS01”
Thank you for your help.
The unofficial docker image on Unraid isn’t supported, you’ll want to install AMP on a Debian or Ubuntu VM in Unraid.
Okay for debian, Thank you
