AMP is not starting after Update
OS Name/Version: Windows 11
Product Name/Version: AMP v2.6.4.2
Problem Description: Today I updated AMP to v2.6.4.2. After updating, AMP wasnt starting up again, manual starting with net start “AMP-ADS01” also didnt work. Then I tried updating with the command promt, and this happend:
PS C:\WINDOWS\system32> ampinstmgr upgrade ADS
[Info/1] AMP Instance Manager v2.6.4.2 built 03/12/2025 15:25
[Info/1] Upgrading instance ADS01
[Error/5] TaskCanceledException
[Error/5] [0] (TaskCanceledException) : The request was canceled due to the configured HttpClient.Timeout of 30 seconds elapsing.
[Error/5]    at Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts)
   at Net.Http.HttpClient.GetStringAsyncCore(HttpRequestMessage request, CancellationToken cancellationToken)
   at ModuleShared.VersionManifest.FetchAsync(String forPlatform)
[Error/5] TimeoutException
[Error/5] [1] (TimeoutException) : A task was canceled.
[Error/5] [2] (TaskCanceledException) : A task was canceled.
[Error/5]    at Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
   at Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
[Error/11] TaskCanceledException
[Error/11] [0] (TaskCanceledException) : The request was canceled due to the configured HttpClient.Timeout of 30 seconds elapsing.
[Error/11]    at Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts)
[Error/11] TimeoutException
[Error/11] [1] (TimeoutException) : A task was canceled.
[Error/11] [2] (TaskCanceledException) : A task was canceled.
[Error/11]    at Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
[Error/13] TaskCanceledException
[Error/13] [0] (TaskCanceledException) : The request was canceled due to the configured HttpClient.Timeout of 30 seconds elapsing.
[Error/13]    at Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts)
[Error/13] TimeoutException
[Error/13] [1] (TimeoutException) : A task was canceled.
[Error/13] [2] (TaskCanceledException) : A task was canceled.
[Error/13]    at Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
[Error/13] Upgrade failed: Failed to find a release matching the specified version: Mainline/2.6.4.2 - This version may no longer be available to download, you should update to a newer version.
  • Step 1: Update AMP on Windows per cmd with ampinstmgr upgrade ADS
Actions taken to resolve so far: I tried to get some help from Chatgpt, didnt work too. Then i tried to reboot my sytem, didnt work too. Also downloading and installing the update with the AMP Instance Manger with gui didnt work.
You’ve got networking issues that are preventing the download of update data. Check your systems internet connection and try again.
