AMP is not currently running 2
I can’t get it to go on it is stuck on this?
Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
PS C:\WINDOWS\system32> ampinstmgr startall
[Info/1] AMP Instance Manager v2.8.0.4 built 24/07/2026 17:10
[Notice/1] ADS01 is already running.
Your AMP instance could not be connected to, this likely means that it is not running or is otherwise not responding.
A reconnection will be automatically attempted in 10 seconds.
If you are performing your first-time setup and are seeing this page for more than a minute then something may have gone wrong with the intial setup. Please consult support in this case.
You can restart AMP manually if it has stopped by opening a command prompt and running:
ampinstmgr startall
If AMP has been recently updated, it may be necessary to restart the AMP-ADS01 service via the Services control panel (services.msc)
Still stuck?
We’re here to help! Select an option below and we’ll help you get running again.
Did you follow the on-screen recommendation? If so, what happened?
