OS Name/Version: Windows Server 2016 / 14393.rs1
Product Name/Version: (Always use the full version number - not ‘Latest’) V2.3.2.10 (just updated)
Problem Description: When using AMP to start my Minecraft server it uses 45gb of ram all the time sometimes 43 when I set limit to 40. But when switched to 80gb it states 85GB is being used up. But in reality Task Manager states only 4gb of ram is being used. Ever since this started the server has had dramatic lag in game.
provides syntax highlighting.
- Step 1 - Started on AMP
- Step 2
- Step 3
Tried on Java edition .bat start. There were no issues but I am unable to change the ram higher than 4gb. The usage was only at 2gb though.
Tried updating AMP and updating instances. Tried changing the Memory usage to low and high numbers. Always stayed higher than what I stated it for.
Googled the issue.
