AMP has commandeered my nginx redirects
OS Name/Version: Ubuntu 20.04
Product Name/Version: AMP Release “Triton” v2.3.2.4, built 22/02/2022 10:57
I have a WP Multisite set up using nginx and MineCraft/ Project Zomboid servers on the same Dedicated Server IP but different domain, which is not, and is not going to be, part of the multisite).
I created the Multisite function and then added a second site, which I tested to make sure it was working and thought nothing more of it.
I then set up AMP and, over the course of a couple of days, set up the server(s), which work as expected.
On going back to the multisite today, the second site url now results in the AMP login screen rather than multisite subsite.
It’s almost certainly not an AMP-led problem but I wondered if those more knowledgeable about the inner workings of such things had a quickfix solution?
AMP just has its own regular nginx config file in /etc/nginx/conf.d - I suspect you’ve got other sites which don’t actually have a specific domain set which may cause the ‘default’ to change.
that would make perfect sense and in hindsight is a very obvious cause which is most likely completely accurate. I shall check it out and report back
