AMP: Error occurred during initialization of VM
OS Name/Version: Windows 11
Product Name/Version: Minecraft / V: 1.20.1
The Minecraft server stopped within 5 seconds of starting, this is not a fault with AMP - you should check your Minecraft servers log files to find out why it is unable to start.
it worked fine for me without any issue yesterday…
i turned off the pc and changed nothing and well now this…
Ofcourse i did upload a plugin Upgradeablehoppers but i dont think a plagin is the cause?..
[(3x backticks for blocks, 1x backtick for a single line) to help make posts readable. This also
provides syntax highlighting.] Amp Logs: (AMP log - Pastebin.com)
 * Step 1: startup pc, run AMP Application manager
 * Step 2: run server
 * Step 3: Ye i know its normal to do this but somehow i managed...
Re-download java and adoptium (latest)
Restart pc, Turn Internet on/off, Redownload paper's: Server.jar
Make sure paper is up to date.
Check drivers out dated.
Easy way to tell if it is the plugin: remove it and see if it makes a difference
Also explain how you uploaded the plugin - via AMP or SFTP or some other way? If another way, file perms will be broken
I upload te plugins by Drag & Drop, And if that did not work SFTP
Yet is a plugin really able to cause this error?
Can you show us your Server Type, Version and jar settings? Also press update inside the instance to download the paper jar
