Amp Error 125 not enough space
OS Name/Version: Debian 13 on Proxnox
Application Version 2.6.3.0
Tools Version 2.6.3
Build Date 26/09/2025 12:10
Problem Description: Not able to start Any instance
Palworld
Minecraft
Asstto Corsa
Exception in API call Core/GetUpdates
UnauthorizedAccessException
[0] (UnauthorizedAccessException) : You do not have permission to use this method (GSMyAdmin.WebServer.GetUpdates) at this time. This method requires the Session.Exists permission.
   at GSMyAdmin.WebServer.WebAttributes.InvokeMethod(String MethodName, JObject Data, HttpContext context, IWebSession Session, WebMethodsBase MethodsClass, IPAddress RealIP)
   at GSMyAdmin.WebServer.ApiService.InvokeAPI(HttpContext context, IWebSession session, JObject data, String requestModule, String requestMethod)
21:44:32
Connection id "0HNFVQEL1MLHF", Request id "0HNFVQEL1MLHF:00000001": An unhandled exception was thrown by the application.
:Valkyrie21:44:53
Non-managed instances exist, autoconfigure cannot guarantee that the configuration is valid!
21:44:54
Unable to find image 'cubecoders/ampbase:latest' locally
21:44:55
latest: Pulling from cubecoders/ampbase
59e22667830b: Pulling fs layer
29848f590a27: Pulling fs layer
f69aa79a54cc: Pulling fs layer
21:44:56
f69aa79a54cc: Download complete
21:45:15
59e22667830b: Verifying Checksum
59e22667830b: Download complete
21:45:16
59e22667830b: Pull complete
21:45:21
29848f590a27: Verifying Checksum
29848f590a27: Download complete
21:45:24
docker: failed to register layer: write /usr/lib/python3/dist-packages/cryptography/hazmat/primitives/serialization/ssh.py: no space left on device
Run 'docker run --help' for more information
Failed to configure new instance PalSrv0101 - Startup failure: Docker returned error code 125. Please check the AMP Logs for further info.
Configuration Failed: Startup failure: Docker returned error code 125. Please check the AMP Logs for further info.
Create Instance Failed: Startup failure: Docker returned error code 125. Please check the AMP Logs for further info.
  • Step 1 Install Amp
  • Step 2 Log in
  • Step 3 Attempt to start instance
Re-Create VM with Larger storge
Reboot system
Try difference instances
Update proxmox and Debian
Reinstalling Docker (Not sure if I did it right)
Re install AMP
Google AMP error 125
Likely your root partition is too small, regardless of the size of the VM
df -h
