Product Name/Version: AMP Instance Manager v2.4.3 built 14/03/2023 21:50
After successfully installing AMP with HTTPS using the script, the webpage is just stuck on “AMP is not currently running”.
Even after waiting for an hour due to the “first-time-setup”, nothing happens.
I don’t know if this is important, in my first installation attempt, I accidentally executed this command directly after the installation finishing because I skimmed over the “first-time-setup” part. sudo service ampinstmgr restart
I also reinstalled it after the first attempt failing by running the script again.
[Info] AMP Instance Manager v2.4.3 built 14/03/2023 21:50
Instance Name │ Friendly Name │ Module │ IP │ Port │ Up
If that doesn’t work you will probably need to delete the failed zip that was downloaded previously, and then try again. It’s in /home/amp/.ampdata/instances/
