AMP desn't start after server's reboot. Browser says - 404 Not Found
OS Name/Version: Ubuntu 22.04.3
Product Name/Version: AMP Instance Manager v2.4.6 built 02/08/2023
Freshly installed AMP doesn’t start after server reboot. The browser shows Nginx error message - 404 Not Found
Although instance is started
 ξ‚° CubeCoders AMP ξ‚° πŸ’»amp@ubuntu-s-4vcpu-8gb-ams3-01 ξ‚° πŸ“~ ξ‚° ampinstmgr status
[Info] AMP Instance Manager v2.4.6 built 02/08/2023 19:48
Instance Name      β”‚ Friendly Name    β”‚ Module     β”‚ IP              β”‚ Port  β”‚ Up
ADS01              β”‚ ADS              β”‚ ADS        β”‚ 0.0.0.0         β”‚ 8080  β”‚
Netstat shows no running services on 8080
 ξ‚° CubeCoders AMP ξ‚° πŸ’»amp@ubuntu-s-4vcpu-8gb-ams3-01 ξ‚° πŸ“~ ξ‚° netstat -tulpn
(No info could be read for "-p": geteuid()=1001 but you should be root.)
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      -
tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      -
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      -
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      -
tcp6       0      0 :::443                  :::*                    LISTEN      -
tcp6       0      0 :::80                   :::*                    LISTEN      -
tcp6       0      0 :::22                   :::*                    LISTEN      -
udp        0      0 127.0.0.53:53           0.0.0.0:*                           -
If I go to the instance folder and start AMP_Linux_x86_64 manually console becomes available
amp@ubuntu-s-4vcpu-8gb-ams3-01:~/.ampdata/instances/ADS01$ ./AMP_Linux_x86_64
[12:22:21] [Logger Info]          : Starting AMP version 2.4.6.0 (Decadeus), built 09/08/2023 17:53
[12:22:21] [Logger Info]          : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[12:22:21] [Logger Info]          : Running in a QEMU KVM environment.
[12:22:22] [Logger Info]          : OS: Linux / x86_64
[12:22:22] [Logger Info]          : CPU: DO-Regular (4C/4T)
[12:22:22] [Logger Info]          : RAM: 7937MB
[12:22:22] [Logger Info]          : AMP Instance ID: 9bec44d4-2d91-4764-9ddd-df5072bad7bf
[12:22:22] [Logger Info]          : Loaded ADSModule version 1.0.0.0 by CubeCoders Limited
[12:22:22] [Logger Info]          : Loaded FileManagerPlugin by CubeCoders Limited
[12:22:22] [Logger Info]          : Loaded EmailSenderPlugin by CubeCoders Limited
[12:22:22] [Logger Info]          : Loaded WebRequestPlugin by CubeCoders Limited
[12:22:22] [Logger Info]          : Loaded LocalFileBackupPlugin by CubeCoders Limited
[12:22:22] [Logger Info]          : Loaded CommonCorePlugin by CubeCoders Limited
[12:22:22] [Logger Info]          : ADSModule requests dependency InstanceManagerPlugin...
[12:22:23] [Logger Info]          : Loaded InstanceManagerPlugin by CubeCoders Limited
[12:22:23] [Logger Info]          : ADSModule requests dependency SystemUserManagerPlugin...
[12:22:23] [Logger Info]          : Loaded SystemUserManagerPlugin by CubeCoders Limited
[12:22:23] [Logger Info]          : Loaded steamcmdplugin by CubeCoders Limited
[12:22:23] [Logger Info]          : Metrics server started OK on port 12820
[12:22:23] [Logger Info]          : ADS startup complete in 355ms
[12:22:23] [Logger Info]          : Updating remote source CubeCoders/AMPTemplates
[12:22:23] [Logger Info]          : Updating existing remote source https://github.com/CubeCoders/AMPTemplates.git...
[12:22:24] [Logger Notice]        : Using keypair with fingerprint 4Re/rjsq7RdB7iKpSiAmonDWG3Q1VXsjzsb1Qu2OOQU=
[12:22:24] [Logger Info]          : SFTP Server started on 0.0.0.0:2223
[12:22:24] [Webserver Info]       : Websockets are enabled.
[12:22:24] [Logger Info]          : Webserver started on http://127.0.0.1:8080
[12:22:24] [Logger Info]          : RouterTimer@10Hz with 2 jobs started
[12:22:24] [Core Info]            : Checking for AMP updates...
[12:22:24] [Logger Info]          : Startup mode is StartApplication.
Already up to date.
[12:22:24] [Core Info]            : AMP is up to date.
Install AMP using β€œbash <(wget -qO- getamp.sh)”
Finish installation in the browser
Reboot the server
I tried to reinstall AMP, same result.
What’s the output of:
ampinstmgr info ADS (run as the amp user)
systemctl status ampinstmgr (run as root)
Hi Greelan, thank you for your prompt reply. It seems the issue solved itself as soon as I posted my request. The only thing I also did is replacing web server address in the config file from 0.0.0.0:8080 to 127.0.0.1:8080.
Anyway, you can see the outputs you requested below.
root@ubuntu-s-4vcpu-8gb-ams3-01:~# systemctl status ampinstmgr
● ampinstmgr.service - AMP Instance Manager
     Loaded: loaded (/etc/systemd/system/ampinstmgr.service; enabled; vendor pr>
     Active: active (exited) since Sun 2023-08-13 12:31:01 UTC; 41min ago
       Docs: https://github.com/CubeCoders/AMP/wiki/AMP-systemd-script-(Linux)
    Process: 712 ExecStart=/opt/cubecoders/amp/ampinstmgr startboot true (code=>
   Main PID: 712 (code=exited, status=0/SUCCESS)
      Tasks: 98 (limit: 9477)
     Memory: 4.7G
        CPU: 18min 7.598s
     CGroup: /system.slice/ampinstmgr.service
             β”œβ”€ 821 /usr/bin/tmux -f /dev/null new-session -s AMP_ADS01 -d "cd >
             β”œβ”€ 825 /home/amp/.ampdata/instances/ADS01/AMP_Linux_x86_64 +Core.W>
             β”œβ”€1118 /home/amp/.ampdata/instances/Wonderland01/AMP_Linux_x86_64 >
             └─1996 /home/amp/.ampdata/instances/Wonderland01/Valheim/896660/va>
Aug 13 12:31:00 ubuntu-s-4vcpu-8gb-ams3-01 ampinstmgr[712]: Can't find custom a>
Aug 13 12:31:00 ubuntu-s-4vcpu-8gb-ams3-01 ampinstmgr[712]: [Info] Waiting for >
Aug 13 12:31:01 ubuntu-s-4vcpu-8gb-ams3-01 ampinstmgr[712]: [Notice] AMP instan>
Aug 13 12:31:01 ubuntu-s-4vcpu-8gb-ams3-01 systemd[1]: Finished AMP Instance Ma>
Aug 13 12:31:03 ubuntu-s-4vcpu-8gb-ams3-01 sudo[857]: pam_unix(sudo:auth): conv>
Aug 13 12:31:03 ubuntu-s-4vcpu-8gb-ams3-01 sudo[857]: pam_unix(sudo:auth): auth>
Aug 13 12:33:03 ubuntu-s-4vcpu-8gb-ams3-01 sudo[1077]: pam_unix(sudo:auth): con>
Aug 13 12:33:03 ubuntu-s-4vcpu-8gb-ams3-01 sudo[1077]: pam_unix(sudo:auth): aut>
lines 1-23...skipping...
     Loaded: loaded (/etc/systemd/system/ampinstmgr.service; enabled; vendor preset: enabled)
    Process: 712 ExecStart=/opt/cubecoders/amp/ampinstmgr startboot true (code=exited, status=0/SUCCESS)
     Memory: 4.7G
        CPU: 18min 7.598s
             β”œβ”€ 821 /usr/bin/tmux -f /dev/null new-session -s AMP_ADS01 -d "cd '/home/amp/.ampdata/instances/ADS01'; /home/amp/.ampdata/instances/ADS01/AMP_Linux_x86_64 +Core.Webserver.Port 8080 +Core.Webserver.IPBinding 0.0.0.0 +Core.AMP.InstanceID 9bec44d4-2d91-4764-9ddd-df5072bad7bf +FileManagerPlugin.SFTP.SFTPP>
             β”œβ”€ 825 /home/amp/.ampdata/instances/ADS01/AMP_Linux_x86_64 +Core.Webserver.Port 8080 +Core.Webserver.IPBinding 0.0.0.0 +Core.AMP.InstanceID 9bec44d4-2d91-4764-9ddd-df5072bad7bf +FileManagerPlugin.SFTP.SFTPPortNumber 2223
             β”œβ”€1118 /home/amp/.ampdata/instances/Wonderland01/AMP_Linux_x86_64 +Core.Webserver.Port 8081 +Core.Webserver.IPBinding 127.0.0.1 +Core.AMP.InstanceID 802f6e88-95d4-48e9-86d8-951df7bf04e0 +FileManagerPlugin.SFTP.SFTPPortNumber 2224 +GenericModule.App.Ports. 2456 +GenericModule.App.Ports. 2457
             └─1996 /home/amp/.ampdata/instances/Wonderland01/Valheim/896660/valheim_server.x86_64 -port 2456 -name vh.dustbin.su -world Wonderland -password Welcome -public 1 -savedir Saves
Aug 13 12:31:00 ubuntu-s-4vcpu-8gb-ams3-01 ampinstmgr[712]: Can't find custom attr constructor image: /opt/cubecoders/amp/plugins/ADSModule.dll mtoken: 0x0a00001e due to: Could not load file or assembly 'SQLite-net, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies.
Aug 13 12:31:00 ubuntu-s-4vcpu-8gb-ams3-01 ampinstmgr[712]: [Info] Waiting for AMP instance to start...
Aug 13 12:31:01 ubuntu-s-4vcpu-8gb-ams3-01 ampinstmgr[712]: [Notice] AMP instance ADS01 is now running.
Aug 13 12:31:01 ubuntu-s-4vcpu-8gb-ams3-01 systemd[1]: Finished AMP Instance Manager.
Aug 13 12:31:03 ubuntu-s-4vcpu-8gb-ams3-01 sudo[857]: pam_unix(sudo:auth): conversation failed
Aug 13 12:31:03 ubuntu-s-4vcpu-8gb-ams3-01 sudo[857]: pam_unix(sudo:auth): auth could not identify password for [amp]
Aug 13 12:33:03 ubuntu-s-4vcpu-8gb-ams3-01 sudo[1077]: pam_unix(sudo:auth): conversation failed
Aug 13 12:33:03 ubuntu-s-4vcpu-8gb-ams3-01 sudo[1077]: pam_unix(sudo:auth): auth could not identify password for [amp]
Aug 13 12:33:21 ubuntu-s-4vcpu-8gb-ams3-01 sudo[1130]: pam_unix(sudo:auth): conversation failed
Aug 13 12:33:21 ubuntu-s-4vcpu-8gb-ams3-01 sudo[1130]: pam_unix(sudo:auth): auth could not identify password for [amp]
and
 ξ‚° CubeCoders AMP ξ‚° πŸ’»amp@ubuntu-s-4vcpu-8gb-ams3-01 ξ‚° πŸ“~ ξ‚° ampinstmgr info ADS
Instance ID        β”‚ 9bec44d4-2d91-4764-9ddd-df5072bad7bf
Module             β”‚ ADS
Instance Name      β”‚ ADS01
Friendly Name      β”‚ ADS
URL                β”‚ http://127.0.0.1:8080/
Running            β”‚ Yes
Runs in Container  β”‚ No
Runs as Shared     β”‚ No
Start on Boot      β”‚ Yes
AMP Version        β”‚ 2.4.6.0
Release Stream     β”‚ Mainline
Data Path          β”‚ /home/amp/.ampdata/instances/ADS01
Unlikely the solution, unless you are running AMP behind a reverse proxy on the same host.
That info command also gives incorrect binding info. Check ampinstmgr status for actual binding
But I do run AMP behind a reverse-proxy on the same host because I installed it with HTTPS support.
Actual binding is -
ADS01              β”‚ ADS              β”‚ ADS        β”‚ 0.0.0.0         β”‚ 8080  β”‚ βœ“
MojsejovSvet01     β”‚ MojsejovSvet     β”‚ Generic    β”‚ 127.0.0.1       β”‚ 8082  β”‚ βœ“
Wonderland01       β”‚ Wonderland       β”‚ Generic    β”‚ 127.0.0.1       β”‚ 8081  β”‚ βœ“
Sounds like your RP configuration is wrong then, check the configuration and see if you can connect to AMP directly. If you can connect directly (wget -qO- http://localhost:8080) then it’s a bad nginx config, not AMP.
