AMP Controller Blank/ Not showing targets
OS Name/Version: Windows 11 / Ubuntu Desktop /
Product Name/Version: AMP 2.6.2
AMP Controller instance manager is blank, not showing any connection errors just does the pulse animation and fails to load anything. Prior to upgrade to 2.6.2 if there was a connection error it would show red at the top of the target name. Now just blank. Target and Controller can ping each other. I can access each AMP target locally, but cannot manage as it’s not from the target. The targets and controller can ping each other for certain, it is not a network issue. This issue only arised after I updated to 2.6.2. I have 20+ servers I have no access to manage at this moment. A little stressed…
Deployment Log
Search...
Services Running
play_circle
:Anonymous09:32:12
   at GSMyAdmin.WebServer.WebAttributes.InvokeMethod(String MethodName, JObject Data, HttpContext context, IWebSession Session, WebMethodsBase MethodsClass, IPAddress RealIP)
   at GSMyAdmin.WebServer.ApiService.InvokeAPI(HttpContext context, IWebSession session, JObject data, String requestModule, String requestMethod)
Exception in API call Core/GetUpdates
UnauthorizedAccessException
[0] (UnauthorizedAccessException) : You do not have permission to use this method (GSMyAdmin.WebServer.GetUpdates) at this time. This method requires the Session.Exists permission.
09:32:14
Slow method invocation: Login took 8943ms to complete.
Slow response: Core.Login took 8944ms to complete.
Slow method invocation: Login took 8511ms to complete.
Slow response: Core.Login took 8512ms to complete.
09:32:19
Slow method invocation: Login took 4682ms to complete.
Slow response: Core.Login took 4684ms to complete.
09:32:21
Slow method invocation: Login took 4188ms to complete.
Slow response: Core.Login took 4189ms to complete.
09:32:30
Slow method invocation: Login took 3105ms to complete.
Slow response: Core.Login took 3106ms to complete.
09:32:38
Websocket closed unexpectedly. State: CloseReceived
09:33:00
Slow method invocation: Login took 3014ms to complete.
Slow response: Core.Login took 3016ms to complete.
09:33:34
Slow method invocation: Login took 2706ms to complete.
Slow response: Core.Login took 2712ms to complete.
09:33:46
Timed out waiting for response from remote instance at http://10.8.0.9:8080/
TaskCanceledException
[0] (TaskCanceledException) : The request was canceled due to the configured HttpClient.Timeout of 100 seconds elapsing.
   at Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts)
   at Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken)
   at AMPAPI.RemoteInstance.GetResponseDynamic(String Module, String Method, Object Parameters)
   at AMPAPI.RemoteInstance.API_Core.Login(String username, String password, String token, Boolean rememberMe)
   at InstanceManagerPlugin.RemoteInstanceManager.Login(String username, String password, String token)
TimeoutException
[1] (TimeoutException) : A task was canceled.
[2] (TaskCanceledException) : A task was canceled.
   at Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
   at Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
Failed to update AMPlinux2 R720 - Could not connect to the remote instance at http://10.8.0.9:8080/. The request was canceled due to the configured HttpClient.Timeout of 100 seconds elapsing.
Authentication token 3fe0320cbb7b for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:33:49
Authentication token 6f50c6d02433 for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:33:51
Authentication token 89339ef0809f for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
:kenny09:33:53
Failed to get target info from http://10.8.0.9:8080/: The request was canceled due to the configured HttpClient.Timeout of 100 seconds elapsing.
09:33:53
Connection id "0HND87HADO7RK", Request id "0HND87HADO7RK:00000001": An unhandled exception was thrown by the application.
Authentication token 95d3432861b1 for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:33:56
Authentication token d7d6f2b90be9 for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:34:02
Authentication token 7d3e0e66f0b7 for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:34:04
Authentication token 411ab8ba0e3d for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:35:44
TimeoutException
09:35:45
Authentication token bf4919c6cf18 for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:35:47
Authentication token c95113782fbc for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:35:52
Authentication token fa8446c29358 for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:35:54
Authentication token f7a6ad9190ed for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:35:56
Authentication token 89d2b6c43ad5 for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:35:58
Authentication token 3620a94f82aa for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:36:01
Authentication token c8f0ce52460e for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:37:41
TimeoutException
09:37:42
Authentication token 2620c78fbe4b for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:37:44
Authentication token 451006fba816 for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:37:46
Authentication token d4d991208846 for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:37:47
Authentication token 55c27f30da41 for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:37:49
Authentication token 40b8f1190042 for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:37:51
Authentication token 3544253583ae for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:39:31
TimeoutException
Authentication token b50b0ef1b6cf for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:39:33
Authentication token 570a944e73b6 for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:39:35
Authentication token aedb40871f89 for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:39:38
Authentication token 21a2a325a9b9 for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:39:40
Authentication token a8e196711912 for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:39:42
Authentication token b27484e9e236 for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
09:39:48
Authentication token 94427f78c05c for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
  • Step 1
    Access AMP Controller via Proxy & Direct (to eliminate possible causes)
  • Step 2
    Browse AMP Controller
  • Step 3
    See that it is blank
Cleared cache, used different browser.
Used different computer to access
Updated AMP controller, Updated AMP targets, Updated Instances
Restarted all (controller, instances, machines) 10+ times
logged in and updated individual instance locally via direct connection (cannot manage but can upgrade)
