OS Name/Version: Debian 12
Product Name/Version: Avorion 2.4.3 (Public)
Problem Description: Any changes to Avorion server.ini settings are consistently reverted within minutes of the change being made, or on a server restart.
- Step 1 - Make changes to server.ini using AMP UI.
- Step 2 - Save changes in AMP UI.
- Step 3 - Close and immediately re-open file in AMP UI to confirm changes were saved.
- Step 4 - Wait between 1-5 minutes.
- Step 5 - Reload or reopen file, contents reset to defaults.
Searched forums for relevant or similar issues, found this article with likely the same problem but no response: “AMP keeps reverting changes to Server.ini in avorion server”.
Notes:
This issue could potentially be resolved by adding the appropriate configuration fields to the AMP server settings for the Avorion server.
