OS Name/Version: Windows Server 2019
Product Name/Version: (Always use the full version number - not ‘Latest’) AMP 2.3.3.4
Authentication System Failure (code 500)
Reason: AMP tried to login to auth server at http://localhost:8080/ but it could not be reached. Please make sure that the AuthServerURL setting in AMPConfig.conf for this instance is valid and addresses your ADS controller/standalone instance.
An error occurred while sending the request. - Unable to connect to the remote server
provides syntax highlighting.
- Step 1
- Step 2
- Step 3
Login.UseAuthServer=True
Login.AuthServerURL - The URL for the ADS instance providing authentication when using UseAuthServer
Login.AuthServerURL=http://127.0.0.1:8080/
Login.MetricsServerPort=12820
Login.UseLDAPLogins=False
Login.LDAPAuthDomain=
Login.LDAPGroupPrefix=AMP_
