Amp Ark Asa Clusters
Tried Every thing listed in the support. But cannot transfer between maps.
Using Ark Astraeos and Valguero Maps, using astraeos as login map and Valgeuro as optonal map we go to transmitter and see the valgeuro map but once at the Valgeuro login we are asked to create a new character. The character we are transferring is not there. Backing out and relogging into Astraeos allow us to download the character we are tranferring. What is wrong?
This may sound silly and repetitive but did you set the cluster id? It must be the same on all maps.
SunlightSurge, Thanks for the reply, yes it is the same for both instances.
