Also, can you post your command prompt shots uncropped? I have a sneaky feeling you started command prompt as administrator which can damage the installation.
Can you humour me and disable IPv6 on your system temporarily? I cant see any reason for AMP to be stalling like that. Also sanity check that there’s no pending/in progress OS updates.
[Info] Release spec: Release - built by CUBECODERS/Michael Biggins on CCL-5950X
[Info] Reconfiguring ADS…
[Notice] AMP Service port ranges have not been specified, using any available…
[Notice] Application Service port ranges have not been specified, using any available…
[Info] New ADS URL is http://127.0.0.1:8080/
[Error] IM was unable to execute the requested command.
[Error] DirectoryNotFoundException
[Error] [0] (DirectoryNotFoundException) : Could not find a part of the path ‘D:\AMPDatastore\Instances\ADS01\provisionargs.kvp’.
[Error] at IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at IO.FileStream…ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at IO.StreamWriter.CreateFile(String path, Boolean append, Boolean checkHost)
at IO.StreamWriter…ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize, Boolean checkHost)
at IO.StreamWriter…ctor(String path, Boolean append, Encoding encoding)
at IO.File.WriteAllLines(String path, IEnumerable`1 contents)
at InstanceManagerPlugin.LocalInstanceManager.()
at InstanceManagerCLI.Core.()
Looks like a permissions issue. Go to the AMP Datastore directory properties, go to the security opens and make sure that the owner is set to NETWORK SERVICE - then use the option to apply those permissions to all files/directories recursively.
Also is D:\AMPDatastore\Instances\ADS01\ the directory structure you’re expecting for the ADS01 instance?
