OS Name/Version: Debian 10
Product Name/Version: AMP 2.4.6.6
Problem Description: After an unexpected power blip and the server rebooting, ampinstmgr.service will not restart and fails with Exit code 1. I looked it up and saw that was a Supplied Function Parameter does not exist error.
Where would I start looking to try and get AMP back online?
systemctl output.
Dec 11 15:18:21 debian2 ampinstmgr[2859]: at System.IO.FileSystem.FileExists (System.ReadOnlySpan`1[T] fullPath) [0x00006] in <84860023ab994fb899a1d6d68e96bfb8>:0
Dec 11 15:18:21 debian2 ampinstmgr[2859]: at System.IO.File.Exists (System.String path) [0x00043] in <84860023ab994fb899a1d6d68e96bfb8>:0
Dec 11 15:18:21 debian2 ampinstmgr[2859]: at System.Linq.Enumerable.TryGetFirst[TSource] (System.Collections.Generic.IEnumerable`1[T] source, System.Func`2[T,TResult] predicate, System.Boolean& found) [0x000
Dec 11 15:18:21 debian2 ampinstmgr[2859]: at System.Linq.Enumerable.FirstOrDefault[TSource] (System.Collections.Generic.IEnumerable`1[T] source, System.Func`2[T,TResult] predicate) [0x00000] in <d79fa9ebec80
Dec 11 15:18:21 debian2 ampinstmgr[2859]: at InstanceManagerCLI.CertSync..ctor (ModuleShared.ILogger log, System.String CustomCertPath) [0x0004d] in <c9a839d3e53148a39cf32240ea424870>:0
Dec 11 15:18:21 debian2 ampinstmgr[2859]: at InstanceManagerCLI.Core.Run () [0x00ab5] in <c9a839d3e53148a39cf32240ea424870>:0
Dec 11 15:18:21 debian2 ampinstmgr[2859]: at InstanceManagerCLI.Program.<Main> () [0x0000b] in <c9a839d3e53148a39cf32240ea424870>:0
Dec 11 15:18:21 debian2 systemd[1]: ampinstmgr.service: Main process exited, code=exited, status=1/FAILURE
Dec 11 15:18:21 debian2 systemd[1]: ampinstmgr.service: Failed with result 'exit-code'.
Dec 11 15:18:21 debian2 systemd[1]: Failed to start AMP Instance Manager.
I’m not sure what caused this in the first place.
The last action I took before the unexpected restart was adding a new datastore.
tried using systemctl to restart the service.
I don’t know where to start looking for Function Parameters that might be missing or errored.
Edit: file systems did not mount correctly on reboot. Issue fixed.
