The most recent says
[14:50:53] [Program Info] : Starting AMP version 2.4.0.8 (Halimede), built 10/10/2022 21:18
[14:50:53] [Program Info] : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[14:50:53] [Program Info] : OS: Windows / x86_64
[14:50:53] [Program Info] : CPU: 12th Gen Intel(R) Core(TM) i9-12900 (16C/24T)
[14:50:53] [Program Info] : AMP Instance ID: 04d4ae31-b8aa-45c8-8b3a-2b1cd115ae34
[14:50:53] [ModuleLoader Warning] : Assembly Newtonsoft.Json was loaded for via fallback handler, check plugin dependencies.
[14:50:53] [Core Info] : Loaded ADSModule version 1.0.0.0 by CubeCoders Limited
[14:50:53] [ModuleLoader Info] : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[14:50:53] [ModuleLoader Info] : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[14:50:53] [ModuleLoader Info] : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[14:50:53] [ModuleLoader Info] : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[14:50:53] [ModuleLoader Info] : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[14:50:53] [Core Info] : ADSModule requests dependency InstanceManagerPlugin...
[14:50:53] [ModuleLoader Info] : Loaded InstanceManagerPlugin version 1.0.0.0 by CubeCoders Limited
[14:50:53] [Core Info] : ADSModule requests dependency SystemUserManagerPlugin...
[14:50:53] [ModuleLoader Info] : Loaded SystemUserManagerPlugin version 1.0.0.0 by CubeCoders Limited
[14:50:53] [FeatureManager Info] : Loaded steamcmdplugin version 1.0.0.0 by CubeCoders Limited
[14:50:53] [ADS Info] : Metrics server started OK on port 12820
[14:50:53] [System Info] : Updating remote source CubeCoders/AMPTemplates
[14:50:53] [FileManager Notice] : Using keypair with fingerprint orinuH+8+o42yKIv95NmEE6kO8QwM4P2DR6rpLNkPZc=
[14:50:53] [ModuleLoader Info] : SFTP Server started on 0.0.0.0:2223
[14:50:53] [WebServer Info] : Websockets are enabled.
[14:50:53] [Core Info] : Webserver started on http://0.0.0.0:8080
[14:50:53] [WebServer Warning] : RouterTimer@10Hz with 2 jobs started
[14:50:53] [System Info] : Checking for AMP updates...
[14:50:54] [System Info] : AMP is up-to-date.
[14:50:54] [Core:admin Warning] : Returned exception from API call ADSModule/GetSupportedApplications
[14:50:54] [Core:admin Error] : FileNotFoundException
[14:50:54] [Core:admin Error] : [0] (FileNotFoundException) : File not found
[14:50:54] [Core:admin Error] : at ModuleShared.Utilities.GetFileHash(String Filename)
at ADSModule.WebMethods.ReadAppTemplates(List`1 data, DirectoryInfo d, RepoSpec manifest)
at ADSModule.WebMethods.BuildAppsCache()
at ADSModule.WebMethods.GetSupportedApplications()
at GSMyAdmin.WebServer.WebAttributes.<InvokeMethod>()
at GSMyAdmin.WebServer.APIService.<InvokeAPI>()
[14:51:01] [System:admin Error] : You cannot start instances you do not own as a non-root user. You are Steve and this instance belongs to NETWORK SERVICE.
[14:51:01] [System:admin Error] : Do not attempt to change the owner of an instance, this will damage your installation. Switch to the correct user and try again.
