OS Name/Version: Linux Ubuntu (bare) 22.04.1 LTS x86_64
Product Name/Version: AMP version 2.4.0.6 (Halimede), built 29/09/2022 16:10
Used the web interface to upgrade from 2.4.0.4 to 2.4.0.6 with the popup notice of update available. After update, my only instance of Minecraft wouldn’t start. AMP WebUI noted I needed to re-enter my licence key so I did in the interface. Web server became unresponsive. Rebooted linux box. On reboot ADS01 runs and webUI works but instance log notes it needs reactivation. Tried reactivation using SSH CLI as user “amp”. Reactivation failed.
CLI INTERACTION:
  CubeCoders AMP  💻amp@linux1  📁~  ampinstmgr reactivate PlayVanilla-101
[Info] AMP Instance Manager v2.4.0.6 built 29/09/2022 16:11
Please enter value for Licence Key
>XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
[Info] Checking licence key...
[Info] Licence Type:  AMP Professional
[Info] Current Usage: 4
[Info] Reactivating instance PlayVanilla-101...
[10:56:08] [Core Info]            : Starting AMP version 2.4.0.6 (Halimede), built 29/09/2022 16:10
[10:56:08] [Core Info]            : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[10:56:08] [Core Info]            : $Loading configuration from {path}...
[10:56:08] [Core Info]            : OS: Linux / x86_64
[10:56:08] [Core Info]            : CPU: Intel(R) Xeon(R) CPU E3-1270 v5 @ 3.60GHz (4C/8T)
[10:56:08] [Core Info]            : AMP Instance ID: 88bc69d6-525e-4633-bfa2-574783c1da0d
[10:56:09] [ModuleLoader Info]    : Loaded MinecraftModule version 1.0.0.3 by CubeCoders Limited
[10:56:09] [Core Info]            : Metrics publishing is enabled at udp://localhost:12820.
[10:56:09] [ModuleLoader Info]    : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[10:56:09] [ModuleLoader Info]    : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[10:56:09] [ModuleLoader Info]    : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[10:56:09] [ModuleLoader Info]    : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[10:56:09] [ModuleLoader Info]    : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[10:56:09] [Core Info]            : Performing activation, please wait...
[10:56:10] [Core Error]           : Activation failed: VerificationFailed
[10:56:10] [Core Info]            : Failed to activate: Verification Failed
[10:56:10] [Core Info]            : -configonly specified or activation performed. Saving settings and shutting down. This is perfectly normal.
[Info] Done.
I notice that the count keeps going up which is kind of alarming and I wonder if that will be an issue when I pass 5 as well
` [Info] Current Usage: 4
Instance, of course won’t start in this state. Here’s the log from it that looks the same always:
[11:16:04] [Core Info]            : Starting AMP version 2.4.0.6 (Halimede), built 29/09/2022 16:10
[11:16:04] [Core Info]            : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[11:16:04] [Core Info]            : OS: Linux / x86_64
[11:16:04] [Core Info]            : CPU: Intel(R) Xeon(R) CPU E3-1270 v5 @ 3.60GHz (4C/8T)
[11:16:04] [Core Info]            : AMP Instance ID: 88bc69d6-525e-4633-bfa2-574783c1da0d
[11:16:04] [ModuleLoader Info]    : Loaded MinecraftModule version 1.0.0.3 by CubeCoders Limited
[11:16:04] [Core Info]            : Metrics publishing is enabled at udp://localhost:12820.
[11:16:04] [ModuleLoader Info]    : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[11:16:04] [ModuleLoader Info]    : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[11:16:04] [ModuleLoader Info]    : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[11:16:04] [ModuleLoader Info]    : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[11:16:04] [ModuleLoader Info]    : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[11:16:05] [FileManager Notice]   : Using keypair with fingerprint L+k4r9lr6WL1FwOJwt8Ady99ffqg8mLosysE1B3jUME=
[11:16:05] [FileManager Info]     : SFTP Server started on 0.0.0.0:2224
[11:16:05] [Core Error]           : No valid AMP licence was found. Please run `ampinstmgr reactivate PlayVanilla-101` to reactivate this instance.
- Start the server
 - Try to reactivate it
I saw some other posts where similar problems (sort of) existed and tried to upgrade without cache. Upgrade performs with no errors, but can’t reactivate instance still. Also tried to put the key into the WebUI and click the reactivate all local instances button, but that continues to lock up stuff and the WebUI won’t respond to browser requests.
Thanks for the help
