OS Name/Version: Proxmox running Debian VM (AMP installed inside Debian VM)
Product Name/Version: AMP Deimos v2.7
AMP becomes unusable after running normally for some time (~30–60 minutes). Initially, everything works correctly, after some time the web panel stops working properly and cant be accessed, along with other instances
The logs show this error repeating itself:
[Core Warning/29] : <my ip>/Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/145.0.0.0 Safari/537.36 tried to use session ID <my session id> - but that session belongs to 127.0.0.1 while attempting to call Servers
Restarting AMP temporarily resolves the issue, but it reoccurs consistently after some time.
Step 1: Start AMP
Step 2: Access the panel via http://10.0.0.179:8080 (my local ip access)
Step 3: Use AMP normally
Step 4: After 30–60 minutes, panel stops functioning correctly
- Accessing AMP only via
http://10.0.0.179:8080(never localhost) - Restarted AMP using
ampinstmgr restartall- temporarily resolves issue
- currently no reverse proxy is in use
- Checked firewall (UFW)
- Checked AMP network configuration:
- Default AMP IP Binding:
127.0.0.1 - Default Application IP Binding:
0.0.0.0
Any help would be greatly appreciated!
