OS Name/Version: debian
Product Name/Version: AMP Instance Manager v2.4.3.6
After an unplanned reboot server, Instance does not start
Instance ID │ 89d57087-c505-4f84-afdd-7309fe199a5c
Module │ ADS
Instance Name │ ADS01
Friendly Name │ ADS01
URL │ http://127.0.0.1:8080/
Running │ No
Runs in Container │ No
Runs as Shared │ No
Start on Boot │ Yes
AMP Version │ 2.4.4.0
Release Stream │ Mainline
Data Path │ /home/amp/.ampdata/instances/ADS01
Writes in logs next:
[20:34:19] [Logger Info] : Loading locale data for xx from xx.json...
[20:34:19] [Logger Info] : Starting AMP version 2.4.4.0 (Decadeus), built 17/05/2023 17:54
[20:34:19] [Logger Info] : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[20:34:19] [Logger Info] : Running in a HyperV environment.
[20:34:19] [Logger Warning] : Current time zone is set to MSK - It is recommended you switch to UTC+0 to avoid time-zone related issues
[20:34:19] [Logger Info] : OS: Linux / x86_64
[20:34:19] [Logger Info] : CPU: Intel(R) Xeon(R) CPU E5-2690 0 @ 2.90GHz (6C/12T)
[20:34:19] [Logger Info] : RAM: 32145MB
[20:34:19] [Logger Info] : AMP Instance ID: 89d57087-c505-4f84-afdd-7309fe199a5c
[20:34:20] [Logger Info] : Loaded ADSModule version 1.0.0.0 by CubeCoders Limited
[20:34:20] [Logger Info] : Loaded FileManagerPlugin by CubeCoders Limited
[20:34:20] [Logger Info] : Loaded EmailSenderPlugin by CubeCoders Limited
[20:34:20] [Logger Info] : Loaded WebRequestPlugin by CubeCoders Limited
[20:34:20] [Logger Info] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[20:34:20] [Logger Info] : Loaded CommonCorePlugin by CubeCoders Limited
[20:34:20] [Logger Info] : ADSModule requests dependency InstanceManagerPlugin...
[20:34:20] [Logger Info] : Loaded InstanceManagerPlugin by CubeCoders Limited
[20:34:20] [Logger Info] : ADSModule requests dependency SystemUserManagerPlugin...
[20:34:20] [Logger Info] : Loaded SystemUserManagerPlugin by CubeCoders Limited
[20:34:20] [Logger Info] : Loaded steamcmdplugin by CubeCoders Limited
[20:34:20] [ErrorReporter Error] : Unhandled Exception: Please report this to the AMP developers.
[20:34:20] [ErrorReporter Error] : [Error] --- Begin Exception Data ---
[Error] OS: Linux (x86_64/HyperV)
[Error] Module: ADSModule, Version: AMP 2.4.4.0
[Error] Release spec: Release - built by CUBECODERS/buildbot on CCL-DEV
[Error] Instance ID: 89d57087-c505-4f84-afdd-7309fe199a5c
[Error] NullReferenceException
[Error] [0] (NullReferenceException) : Object reference not set to an instance of an object
[Error] at ADSModule.WebMethods.BuildAppsCache ()
at ADSModule.ModuleMain.TryGuessIMImages ()
at ADSModule.ModuleMain.PostInit ()
at GSMyAdmin.ModuleLoader.RunPostInit ()
at GSMyAdmin.Core.Run ()
at GSMyAdmin.Program.Main ()
[Warning] Last error was raised less than 60 minutes ago, error report will not be submitted.
[20:34:20] [ErrorReporter Info] : ####################################
[20:34:20] [ErrorReporter Info] : # Self Diagnostics #
[20:34:20] [ErrorReporter Info] : This exception was caused by a null reference or null argument. This is usually caused by a bug in AMP, or a plugin.
[20:34:20] [Logger Info] : The exception message was: Object reference not set to an instance of an object
What do you recommend to do to fix it?
