OS Name/Version: Ubuntu 20.04 LXC (Proxmox 7.1)
Product Name/Version: 2.3.2.0
I’m running 6 nodes, 1 front end for management/auth and 5 nodes for gameservers I host internally on the network. Of the 5, this one specific node will not keep ADS01 running. For the life of me, I can’t figure out what’s sending the SIGUSR1 to shut it down.
[19:05:02] [Core Info] : OS: Linux / x86_64
[19:05:02] [Core Info] : CPU: Intel(R) Xeon(R) CPU E5-2620 v2 @ 2.10GHz (6C/0T)
[19:05:02] [Core Info] : AMP Instance ID: aea0c3af-dbd5-4b24-abbe-342de6b37ce8
[19:05:02] [ModuleLoader Info] : Loaded ADSModule version 1.0.0.0 by CubeCoders Limited
[19:05:02] [Core Info] : Metrics publishing is enabled at udp://amp.lahni.com:12820.
[19:05:02] [ModuleLoader Info] : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[19:05:02] [ModuleLoader Info] : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[19:05:02] [ModuleLoader Info] : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[19:05:02] [ModuleLoader Info] : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[19:05:02] [ModuleLoader Info] : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[19:05:02] [ModuleLoader Info] : ADSModule requests dependency InstanceManagerPlugin...
[19:05:03] [ModuleLoader Info] : Loaded InstanceManagerPlugin version 1.0.0.0 by CubeCoders Limited
[19:05:03] [ModuleLoader Info] : ADSModule requests dependency SystemUserManagerPlugin...
[19:05:03] [ModuleLoader Info] : Loaded SystemUserManagerPlugin version 1.0.0.0 by CubeCoders Limited
[19:05:03] [ModuleLoader Info] : Loaded steamcmdplugin version 1.0.0.0 by CubeCoders Limited
[19:05:03] [Core Info] : Metrics server started OK on port 12820
[19:05:03] [FileManager Notice] : Using keypair with fingerprint <Redacted>
[19:05:03] [FileManager Info] : SFTP Server started on 0.0.0.0:2223
[19:05:03] [WebServer Info] : Websockets are enabled.
[19:05:03] [WebServer Info] : Webserver started on http://0.0.0.0:8080
[19:05:03] [Logger Warning] : RouterTimer@10Hz with 2 jobs started
[19:05:03] [Core Info] : Checking for AMP updates...
[19:05:04] [Core Info] : AMP is up-to-date.
[19:06:00] [RemoteAMPAuth:Anonymous Activity] : Authentication attempt for user AMP_SYSTEM from 192.168.65.60
[19:07:08] [RemoteAMPAuth:Anonymous Activity] : Authentication success
[19:07:17] [API:AMP_SYSTEM Activity] : Changing setting ADSModule.NewInstanceDefaults.DefaultAuthServerURL to http://192.168.65.60:8080/
[19:11:34] [Core Info] : Stop requested: SIGUSR1 Recieved
[19:11:34] [Core Notice] : AMP shutdown requested.
[19:11:34] [Core Notice] : Stopping Application...
[19:11:39] [Core Notice] : Stopping Web Server...
[19:11:39] [WebServer Info] : Web server shutdown.
[19:11:39] [Core Notice] : Goodbye!
Rest in peace - Stephen Hawking 1942-2018
[19:11:39] [Logger Warning] : RouterTimer@10Hz stopped
- ADS01 successfully starts on boot. 2 more instances also boot successfully. A few minutes will go by and ADS01 will automatically shut itself down
- I just started it manually using
ampinstmgr -a
to see if it’s just at system startup or if it’ll die this way too. So far, when started manually, it’s staying up.
Actions taken to resolve so far: Tried to see if there was any obvious error messages in the logs, but nothing that jumped out at me.
