ADS is running 2.6.0.6 BUT its been upgraded to 2.6.0.12
OS Name/Version: Win 10 Por Version 10.0.19045 Build 19045
2.6.0.6 and 2.6.0.12
Problem Description: when the browser is open it shows its running 2.6.0.6 but it has been updated according to the instance manager to 2.6.0.12
Deployment Log shows this
`Loaded ADSModule version 2.6.0.6 by CubeCoders Limited
Loaded FileManagerPlugin by CubeCoders Limited
Loaded EmailSenderPlugin by CubeCoders Limited
Loaded WebRequestPlugin by CubeCoders Limited
Loaded CommonCorePlugin by CubeCoders Limited’
But Instance.json shows this
“FriendlyName”: “ADS”,
“Description”: null,
“WelcomeMessage”: null,
“Group”: null,
“IsHTTPS”: false,
“AMPVersion”: “2.6.0.12”,
“AMPBuild”: “20250224.1”,
“PreviousVersion”: null,
“PreviousBuild”: null,
  • Step 1 run ads
  • Step 2 update ADS
  • Step 3 its still not updated
i have stopped all instances and installed from a new download
i have used the amp instance manager to update the ADS (which shows 2.6.0.12)
i am at a loss as to what else to try
