After upgrading ADS to version 2.3.2.0 it fails to start with this error
[Error] --- Begin Exception Data ---
[Error] OS: Linux (x86_64/None)
[Error] Module: ADSModule, Version: AMP 2.3.2.0
[Error] Release spec: Release - built by CUBECODERS/buildbot on CCL-DEV
[Error] Instance ID: 56cc8046-466e-4166-8aff-a2449f9c1193
[Error] ArgumentException
[Error] [0] (ArgumentException) : An item with the same key has already been added. Key: 0
[Error] at Collections.Generic.Dictionary`2[TKey,TValue].TryInsert (TKey key, TValue value, Collections.Generic.InsertionBehavior behavior)
at Collections.Generic.Dictionary`2[TKey,TValue].Add (TKey key, TValue value)
at GSMyAdmin.WebServer.WebMethods.BuildSettingSpec ()
at (wrapper synchronized) GSMyAdmin.WebServer.WebMethods.BuildSettingSpec()
at GSMyAdmin.WebServer.APIService.AddCoreModule ()
at GSMyAdmin.WebServer.LocalWebServer.Start ()
at GSMyAdmin.Core.Run ()
at GSMyAdmin.Program.Main ()
[Warning] Last error was raised less than 60 minutes ago, error report will not be submitted.
[12:20:38] [ErrorReporter Error] : [Error] --- Begin Exception Data ---
[Error] Instance ID: 0ab6df23-4e97-42fc-b7ee-780879163b31
[12:20:38] [ErrorReporter Info] : ####################################
[12:20:38] [ErrorReporter Info] : # Self Diagnostics #
[12:20:38] [ErrorReporter Info] : AMP Diagnostics could not establish a solution for this exception.
I still had the cache file for 2310 (AMPCache-2310.zip), just unzipped it in ads folder and overwrote. I know it’s not recommended to downgrade but I was curious to know if downgrading would help.
I can confirm that @FeminalPanda’s solution worked for me.
Running ampinstmgr --nocache --UpgradeAll
followed by a reboot of the machine fixed it. I ran the UpgradeAll command before coming here, but I didn’t reboot. So I guess the reboot is somewhat crucial here.
Question, are you able to manage a new instance since the upgrade, i have tried two different games, zomboid and craftiopa and get an error.
"AMP was unable to reach its backend at https:///?remote=1c962997-aaed-40eb-b83a-541ace4d9daf
This probably means that AMP is not running and you are currently looking at a cached page. Please check that AMP is running. This page will refresh automatically in 5 seconds."
OK. So i tried upgrade --nocache before creating this post but forgot to mention it and it didn’t work. I tried again just now, but only upgrade ads with nocache and reboot(this shouldn’t matter) but to no avail. But, third time is the charm(?) I did nocache upgradeall reboot. And now ADS works fine? Whyyyyy the reboot tho? IMO rebooting should NOT be required. at. all… ever.
Windows has a habit of caching assemblies even if AMP tells it not to, so occasionally a restart is required after doing certain types of updates. If you’re on Linux you probably just got caught the other side of a silent update.
Occasionally AMP gets an update that doesn’t result in a version number bump, usually happens if there’s some minor issue shortly after release. So a ampinstmgr --nocache upgrade is required to get that update since it’d have the same version number.
