OS Name/Version: Ubuntu 20.04
Product Name/Version: AMP Release "Halimede"v2.4.0.8, built 10/10/2022 21:18
My AMP Admin user seems to have corrupt permissions I have 7 Instances but can only see 2, cannot make new users, can make more instances (that i cannot see on the web portal but can in adsinstmgr), I tried changing permissions in the web portal but get met with an error that says
There is no single-user role matching this user’s ID. If you have upgraded from a previous version of AMP you will need to re-create this user.
I have tried to upgrade everything with
ampinstmg --nocache upgradeall
I also tried updating the login with
ampinstmgr resetlogin
This happened while editing another user’s permissions, upon logging in the next time i was met with this problem.
Is there a way I can reset the admin permissions or profile?
