Add ip connection
OS Name/Version:
provides syntax highlighting.
  • Step 1
  • Step 2
  • Step 3
I also bought a license from you, and I would like to know if I can add multiple IPs to your panel. I have a dedicated server with 9 IP addresses; would I be able to add all of them?
AMP doesn’t currently support using the same port on multiple IPs if that’s what you mean. Though it is planned in a future release as far as I know.
