Add a check if "arch" command is not found
OS Name/Version: Arch Linux
Product Name/Version: AMP 2.4.3.6
Problem Description: I was unable to update AMP with in-built ampinstmgr upgradeall or by running the bash <(wget -qO- getamp.sh) installation script with/without the upgradeall argument.
The coreutils package in Arch Linux doesn’t install the arch command, and the script ignores any aliases set, i.e. alias arch='uname -m' in ~/.bashrc for the root user, which should give the same value.
Actions taken to resolve:
Had to manually run base64 -d and gzip -dcq to decode the file and change arch to uname -m then run it locally.
Probably a slip-up since I used this same method for installing AMP initially. It might be helpful to add a check if the command exists to prevent this though since it fails to install outright on Arch at the moment unless you make this change.
There’s actually a new version of the script in testing that has a fix for this in :slight_smile:
