OS Name/Version: Microsoft Server 2019 GUI
Product Name/Version: AMP Release Halimede v2.4.0.4, built 10/09/2022 16:30
Problem Description: I’ve scheduled a backup of my Garry’s Mod server to take place every day, however I’ve noticed it hasn’t actually been backing up, so I tried to do a manual backup. I’m met with the error of “A backup is already in progress” when I try to start a backup.
Whether it is related or not, I’ve noticed my Garry’s Mod server is showing as starting under the notifications tab at the bottom right, however the server has been running for a while and the notification won’t go away. I’ve tried restarting and reinstalling the server to remove the notification but it persists.
provides syntax highlighting.
Navigate to Schedule for Garry’s Mod server.
Schedule a ‘Take a backup’ through Simple Time Interval trigger to take place at 00:00 every day.
Backup should backup at 00:00 every day. But does not. Then try to do a manual backup and receives the “a backup is already in progress” error.
Actions taken to resolve so far: Unable to resolve so far.
“[00:54:54] [System:BobbyB Warning] : Scheduled task failed. ‘Event.LocalFileBackupPlugin.TakeBackup’ was not completed. A backup is already in progress.”
The below notification is still there too. Could that be something to do with it? Again, this instance is already running but the notification will not go away.
Not that I can see of. Within the server.cfg in the cfg folder of the Garry’s Mod server, I’ve got the rcon_password. That’s the only relative thing in regards to the RCON. That starting instance notification did seem to be bugging out even with the first installation of the Gmod server, and it seems to have persisted through to the second installation, so I don’t even think it’s trying to start a server now seeing as it’s already up, if that makes sense.
I should add, this seems to be the only server I’m having issues performing backups with. My Minecraft server appears to be fine.
So with that updated, I’m still getting the same error as initial post “backup is already in progress” with srcds01 still ‘starting instance’ on the home screen of AMP. Tried a restart, still there.
I’ve also added a second Garry’s Mod server with a fresh install and new RCON pass, and still receiving the “a backup is already in progress” error, even though it is a fresh install.
